eric96ser »
https://forums.nicoclub.com/eric96ser-u2794.html
Tue Oct 29, 2002 11:17 am
The grades of pistons are just like the grades of bearings. They refer to the size of the bore in the block. I think a stock SR20 is 86mm, but the pistons come in sizes that are measured to the .01 of an inch. Almost every SR20 I've seen has grade 2 pistons. Look at the back of the block, that number is the piston grade. There is no way to tell what size pistons you need without taking the head off.
