Pistons
namrak
Where can i get pistons near stock compression ratio, for a relativly good price, I think i blew a ring and it damaged a piston also, just need it to hold out till I get a new motor.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Check http://www.Flatlanderracing.comThey have engine rebuild kits for stock bore and standard oversizes.
JNM240
I also have 4 pistons out of my 1990 SOHC for sale. If you have a SOHC, they will be 8.6:1 compression ratio. If you have a DOHC, the will make 11.1:1 compression ratio. They are complete with rings, wrist pins, and wrist pin locks. $75 plus shipping if you are interested.
1991240xs
jnm..would i need anything else to install these into my dohc (other than the new gaskets when i put them in)..or is everything you're selling enough~
JNM240
Yes, new gaskets, and you would really want new rings, since these rings have 191k miles on them. Other than that they drop right in.
