480sx wrote:I would be pretty pissed at that tuner, wow. Who tunes a car with AEM EMS to 11 psi and doesnt mess with timing.. Dude i would be raising hell. At least get your money back from them.
Idk about your engine, you should prly do a leak down test and see what you come up with.
yeah this shop claims to know alot about the ems, but when i went back home to check what the tuner did to the map, all i saw was that he tuned the fuel map a bit and then did boost fuel correction, but then i went to check the ignition map(timing map) it was still stock.
esahuque wrote:Well if you put oil in the cylinder and it didn't change your compression then its going to be the head gasket or a bent valve. If you add oil to the cylinder and it raises your compression than its your ring-lands.
yeah i was thinking that too, could be the headgasket part where the oil flows through blew, but am sure its the piston rings that are broken, since there's quite a bit of smoke coming out of the exhaust.
anybody have an answer to the side question?
