BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Tue Jan 20, 2009 5:36 pm
I've owned numerous Nissans with four cylinders; 1987 D21 pickup w/ NAPS-Z 2.4l and 90,000 miles, 1987 Pathfinder with same engine and 175,000 miles, 1992 Stanza with KA24DE engine and 150,000 miles, 1999 Sentra with GA16DE engine with 92,000 miles (1.6l), 2004 Frontier with KA24DE variant and 40,000 miles, and 2007 Versa with MR18DE with 50,500 miles. ALL of these vehicles made the "piston slap" sound when cold... I know what sound you're talking about, it sounds like it's coming from deep within the block and is a "thunk thunk thunk" sound, right? Goes away when you accelerate and dissappears when warm? My Versa is the only vehicle I have ever bought new, and it has made this sound since day one; 50,000 miles later, it hasn't changed, even with synthetic oil. This seems to be very common with Nissans and Toyotas (yes, even TOYOTA engines make noise! Have you heard a Camry 4 cylinder lately??!?) One thing you (all) need to know is that engines built today are not built like they once were; pistons are often cast with far less metal (the skirting has been reduced to almost nothing), to reduce piston weight and increase performance and mileage. The tradeoff? there will be some very minute piston slap in some engines, so some noise is inevitable. The engines are designed with the knowledge that the piston will expand slightly. GM was recently under fire for this same issue, however, they took the design approach to an extreme not tolerable by industry standards; their V8 gas engines actually sounded like diesels!
That said, your noise is normal; just drive the car and be sure to be easy on her once she warms up. But, since you only have 11k, see what the dealer says.
