I see amajor problem, you should re-post this with the caps lock OFF93s13 wrote:HERE IS THE SET UP IM THINKING ABOUT, IF YOU GUYS SEE ANY PROBLEMS, LET ME KNOW BECAUSE NOTHING IS PURCHASED YET BESIDES THE MOTOR.
JUN STRENGTHENED VALVE GUIDESJUN TITANUIM VALVE RETAINERSJUN RACING VALVE SPRING SETTOMEI 1.5 MM HEAD GASKETTOMEI PISTONSTOMEI CONNECTING RODSJUN CAM SPROCKETSTOMEI CRANKSHAFTNISMO 555CC INJECTORSTRUST OIL COOLERAJUSA FULL GASKET SET
STILL UNDECIDED ABOUT THE TURBO, SOMETHING QUICK SPOOLING PROBABLY. THE BLOCK AND HEAD ARE GETTING PORT AND POLISHED. WHAT SHOULD I BORE THE BLOCK OUT TO? 84 OR 85 MM?
