piston selection
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
ok I ordered a piston from phase 2 (oem one) cus one of mine had cracked, and I got a 75f stamped on the top of it. I just realized that the ones in my motor have 54c. what does this mean and can i use the 75f? will it be terribly out of balence? i'm not trying to kill these bearings after 10k miles or anything
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Im not 100% sure on your piston, but when I ordered a single rod from The NISMO shop the weight difference was so great compared to my originals that my machinist could not balance the set making the rod useless. I hope your experience with replacing just one piston turns out better then mine.
hungryjoseph
blah gay. I might end up calling the machine shop or trying to get the pistons weighed at one of my school's chem labs. but i have a feeling it's going to be really unbalenced.
hungryjoseph
will cp pistons work with the stock rods? no isssues with the part where the rod and piston meet? i forget what they cylinder thing is called
edit
wrist pin lol
Modified by hungryjoseph at 11:43 AM 5/30/2009
V8slayr
Car: 97 240sx
Yes they will. I running 87 mm CP pistons on my stock rods.
hungryjoseph
where do i find information on how to gap the cp rings? i've looked over google and nico and haven't found anything useful
also, for installing the cp pistons in the stock bore, do I need to make sure the piston clearence is within spec with cp's manual? I know the piston expands more than the oem one so I can imagine the clearence being larger than stock. is this something they already take into account when they make the piston and something I don't have to worry about?
Modified by hungryjoseph at 10:14 AM 5/31/2009
240life
The SR rebuild video does a in depth demonstration on how to properly gap rings
hungryjoseph
ok i did some more research and thinking and i think i basicaly answered my own question. there are three grades to the piston, 1, 2, and 3. i don't know much else beyond that other than i ordered a 1 and i need a 2
