What happened?
This all the way. if you try and re-use the head you will leak through the gasket, and end up doing more damage.t.mcginley.jr wrote:Definitely looks like either detonation happened or a bad head gasket, or both. The bad news is that the pitting is right where the sealing/fire rings on the headgasket are so there's a good chance it won't seal properly if you reinstall as-is. If the pitting was in the chamber itself you could smooth it out and be fine, but on the edge is different. If you really wanted you could have the heads decked, but the pitting looks too deep for that (a shop would have to measure it).
It would probably be cheaper to just pick up a new head or set of heads, especially since they are just NA heads.
