what's generally the cost on some pauter/ross combo?WDRacing wrote:Pauter rods/Ross pistons...but it depends on your power goals and budget.
I saw some people with that setup, arias/eagle combo. not going for 600..more like 350hpkouki_hmongster wrote:arias piston 8:8.1 compression (.020"oversize), and eagle rods. pistons are made for high boost. unless you want to push over 600+whp then you should use better rods.
I want longevity, reliability too. Build the motor to handle 500+, but only run it at 75%.Craving4Boost wrote:350hp? flywheel power or wheel hp? you can definately make 350hp with stock pistons/rods. have an effecient set up + good tune.
My next set will be crowers they are plenty good for my power level and i dont want to have to worry about notching again. thats if my pauters ever go bad lol480sx wrote:I just got a set of crower rods, they are amazing. Look to be on par if not better than paulter. Ill toss up a pic when i get home, i had never seen them before but they are massive.
Anything crower makes is good, enough said. They also will make Ti rods if you ask for it. Stupid strength and light weight ftmfw..
I blew my engine four times and rebuilt it seven times. One was a HIB situation.AirborneGSXR wrote:Did your motor blow again Cory? Hows the transmission?
I always wondered why you refused to just stop rebuilding motors and buy some freaking rods/pistons...
Modified by AirborneGSXR at 1:36 PM 8/12/2008
