Postby
TruboostPerformance »
https://forums.nicoclub.com/truboostperformance-u2594.htmlSun Jan 19, 2003 8:35 am
Need some info on new piston rings? Had a misshap with a palm pilot monitoring device that resulted in two piston rings bad, I have read here on a few post but never could confirm what set exactly are stronger than stock rings? A few post said that Altima rings are much stronger anyone can give anymore info on this thanks, have get the new rings in asap...Thanks...
Postby
GlacierFreeze »
https://forums.nicoclub.com/glacierfreeze-u14207.htmlSun Jan 19, 2003 8:35 am
I keep hearing that these are better than stock, but how much better? Anyone have a good guess at how much more hp/strain you can put on your motor with these over stock rings? Thanks.
Postby
im two techno »
https://forums.nicoclub.com/im-two-techno-u11846.htmlSun Jan 19, 2003 8:35 am
I told you guys they were cheap. They are still a stock rings but the thing about them is they are made of chromolly steal and for that reason they are stronger but how strong is yet to be determined.
Postby
brage »
https://forums.nicoclub.com/brage-u1601.htmlSun Jan 19, 2003 8:35 am
You sure you have bad rings ? If you haven't tore it down yet, I'm willing to bet it is the ring lands of the pistons that failed, not the rings themselves...
