andrave »
https://forums.nicoclub.com/andrave-u6358.html
Tue Jul 06, 2004 12:49 pm
I ordered some rings for my engine (nissan parts) and they came but they aren't clearly labeled as to which is which, and I don't know which ring is which. I could compare them to my stock rings but.. I took them off the pistons already.Anyway the fsm doesn't say anything about it. There are little paint codes on the side of the rings, one is yellow and one is white, I believe?
Also, what clearances should I run? the rings are within the tolerances in my FSM the way they are (at least on cyl #1) but my brother advised me to run the maximum or slightly over the maximum because he said turbo cars heat up the rings more, causing them to expand and possibly buckle.
Anyway if anyone could advise me as soon as possible, I'd appreciate it.
