Piston Ring Interchangeability (DE and DET)
FTRS14.5
Hey,Just wondering if anybody knew the interchangeability of the SR20DE piston rings and the SR20DET piston rings? I've spoken to HT, Phase2, Enjuku, and JGY saying that it "could" work, but they all sounded "iffy" about it. I'm waiting to hear a response from Secret Services. I also contact Courtesy Nissan. I spoke to one person and he said that they had the actual Piston Ring Set for the DET but he can't seem to find it on the shelf. Then I called back and another dude said that they don't carry it and that a 300zx set would work(?). So if anyone has any insight on this, I would greatly appreciate it. This is the last step before the motor goes in and I can finally finish this project. So PLEASE, HELP!!!!!Thanks in advance!!!
nismodave
Did you talk to Bruce at Courtesey?
He is very knowledgeable.
Here are the rings I bought through courtesy for my SR.
http://www.courtesyparts.com/M...00002
FTRS14.5
Bruce is no longer working at Courtesy. Spoke with Matt and he stated that he hasn't worked there for over 4 months. Anyways, I called Enjuku again and the tech said that the SR20DE ones will work. So I guess that's the route I will be going until I find out otherwise. I'm still waiting on that response from Secret Services though......
sil80S13
Car: showing off my n/a sohc ka. har har har
the part numbers are the same. so i believe they probably are, u might wanna check on that at the dealership. just check the part numbers.
