ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Mon Jul 24, 2006 2:52 am
yeah, putting in the pistons into the block is a PITA. It makes things much easier if you have one of those tapered piston ring compressor but I doubt you do. I found out that the oil rings always pop out and causes the piston to not go any further. Make sure your ring compressor is flush with the block and tap on the piston pretty quickly. They will pop in eventually.
