piston head gasket confusion
jongonzoS13az
Car: 90 240sx
alright at all the online stores i go to they only sell cometic head gaskets and cf forged pistons now heres the confusion cf pistons only come with .89-89.5 bore and cometic gaskets come in like a .90-.91 is there any good quality metal gaskets that would fit .89-.89.5 i mean what do you guys use?
480sx
Car: 1996 Pearl White 240sx
Fel-pro is all you need. Most guys who are going for 500 or under Hp just use a stockish head gasket. Those MLS gaskets are a pain, i know from firsthand experience. Not worth the aggravation IMO.
SR24DET
Car: RMS13
You really dont recamend an aftermarket headgasket?! I am building my KA and i wana boost it, maybe 30psi. I dont wana blow my headgasket so im gona get a metal one as well. How hard can it be to put on. I already have the engine torn down almost all the way. Im haveing the cylinders honned. What more then just put the headgasket on do i have to do? Its a gasket...
Florida240sx
It's a piece of crap IMO. Lot of people don't like them. I've had a ba dperosnal experience. And now of wuite a few people who have had problems. My buddy has a ca18 rebuilt by him with 0miles and oil is leaking out the block. ARP headstuds BTW
Ligouri Rd
Car: '96 Nissan 240SX
jongonzoS13az wrote:alright at all the online stores i go to they only sell cometic head gaskets and cf forged pistons now heres the confusion cf pistons only come with .89-89.5 bore and cometic gaskets come in like a .90-.91 is there any good quality metal gaskets that would fit .89-.89.5 i mean what do you guys use?
Race Engineering (Clicky) stocks both the 90 and 91mm bore head gaskets. The 90 is what you use with 89/89.5mm pistons, that is what I have with my stock bore CP pistons. The deal with the cometic is that you must have an absolutely immaculate surface on both the head and the block. I had my block and head slightly decked and polished to generate that kind of a surface finish. I have had two Cometic head gaskets with no issues.
WDRacing
SR24DET wrote:You really dont recamend an aftermarket headgasket?! I am building my KA and i wana boost it, maybe 30psi. I dont wana blow my headgasket so im gona get a metal one as well. How hard can it be to put on. I already have the engine torn down almost all the way. Im haveing the cylinders honned. What more then just put the headgasket on do i have to do? Its a gasket...
Maybe 1 out of 250 KAT's will ever run over 20psi. Unless you're really striving for big numbers the stock headgasket or stock type is just fine. Felpro FTW!!!
WD
C-Kwik
I'd agree with WD here. Frankly, if that much power is truly in sight, I'd probably consider o-ringing the block.
SR24DET
Car: RMS13
think its that important? with honned cylinders, forged internals, metal headgasket, and ARP studs, what would stop me from going that high. I was thinking daily at 20psi and when at the track 30psi. you think with those mods it wont hold up? I emailed BC and they said with those internals i shouldnt go lower then 16psi. did i mention low compression pistons and a thick headgasket.
jongonzoS13az
Car: 90 240sx
naw im only looking to run 11psi of boost max. whats the best basic gasket avail?
WDRacing
SR24DET wrote:think its that important? with honned cylinders, forged internals, metal headgasket, and ARP studs, what would stop me from going that high. I was thinking daily at 20psi and when at the track 30psi. you think with those mods it wont hold up? I emailed BC and they said with those internals i shouldnt go lower then 16psi. did i mention low compression pistons and a thick headgasket.
Perhaps you have different goals then most, but if you use a turbo big enough to support 30 psi you'll have a very laggy daily driver. Not to mention that anything more the 400whp makes the car nearly undriveable on boost. It only takes 20psi give or take to go past the 400 mark. With 30psi you're going through trannies and rear ends since you'll need slicks to hook up.
See my point?
SR24DET
Car: RMS13
i see your point but if i run it at 20 daily. then boost higher for fun. Im looking into a Z32 and maybe a z33 trany. Those will be able to handle the high HP. I am not looking into to big of a turbo but i still know what you mean. Just things i have been rolling around in my head.
WDRacing
I totally hear ya man. I went with a large turbo on my Skyline and ruined it. Was fun for drag racing and nothing else...
WD
SR24DET
Car: RMS13
ya in texas and you have a skyline. what kinda? R32, R33, R34. GT, GTS, GTR. Coupe, Sedan, Wagon? Thats awsome.
