Q45tech wrote:$1218 is for just the chain guide replacement and a new oil chain.Valve cover reseal and an oil pan removal [if required] adds another $1000 [$1100 ifit is a 't' or 'a' model].Removing a [driver’s side] head, sending it out for rebuilding would add$1200-1500-$1800 if the valve cover was off {$300} [very time consuming with engine in car.Pretty soon you get to the price of a used take out engine which still requires newchain guides and oil chain plus who known how much in new hoses, water pump,reseals, knock sensors R&R in general.To do the job right for the long haul is $5,000 to $6,000 unless you can find techswho work for nothing.The thing is all engines [valve covers] leak sometime and all hoses and electricalharnesses become brittle and all connectors get corroded.In the 90-93 Q case all the engines are the same age low miles does not mean asmuch as heat exposure and good maintenance does.If you are going to keep an engine 10-12 years you are going to have to go throughthese expenses....buying a 93 engine may or may not have less heat exposure [hotidling vs highway driving] to the rubber hoses.It is always more economical [faster] to replace all external components when it issitting on an engine stand.Warranty is our problem -- the customer expects everything to work for a year eventhough we may use his old injectors, rails, plenum, throttle body, etc. We try toguess [correctly] which old or older [cleaner]parts to use.One warranty claim to replace a knock sensor can cost us $800 or an injector $250-$550 or a crank angle sensor or worse add a tow to either ...there goes the jobprofit.What the take out company engine warranty gives you is another rough engine [for3-6 months] where you get to do all the R&R again and pay to ship the bad oneback.May the FORCE be with you in selecting one.A used Japanese take out engine will still require that you change out the old styleguides, water pump, reseal the valve covers, change the plenum hoses, injectors ??,new spark plugs, and knock sensors and harness.One to two days of R&R before you even think of putting it in a car as it arrives.Transfer the starter, build it up with PS pump, alternator new belts , thermostat, newwater hoses, charge ac system.Some times you can get one as bad as you are taking out.We end up charging $2,000 just to get the take out engine $2,500 ready to installthen the $1,000 for the swap.
Why am I so damn nice.
