i have so many questions that its not even funny...
i am going with eagle rods.....estimated to hold 600hp
i was thinking of getting the BC Fully balanced crank for reduced vibration to make the setup more reliable but is it worth-it? or can i just get the stock crank re-surfaced and blueprinted and balanced and will the stock crank shaft be able to hold up to 450hp all day with no problem?
i dont know anything about boring size...+20mm i dontknow what those are or if i need anything like that for my build with my power needs will the stock bore be just fine and reliable for my needs?
i am going with the jgs starter kit w/ .50 trim & .63 turbine A/R. i am also going to get a 3" downpipe. any recommendations on the downpipe? turbo setup from this place
http://www.phase2motortrend.com/jgstukitstpa.html
im going to get 720cc injectors, just dont know from who though.
what about my ignition? do i need a better ignition set up than factory in order to start the motor after its complete? any suggestions?
what about the fuel rail? will i need to upgrade that as well? if so what will i need to do so? any suggestions?
i am going to upgrade the pistons for for reliability reasons and for peace of mind i just dont know what compression ratio would be most effective for most power with most reliability? any suggestions?
i am going with the walbro 255 fuel pump.
i was also thinking of going with the brian crower cam shafts... i just dont know what stage to get for my power goals. any suggestions?
i was also thinking of going with the brian crower intake valves. any suggestions?
i was also thinking of going with the brian crower valve dual spring retainer kit. any suggestions?
im sorry i just have so many questions.
any help will be most helpfull
