piston damage (pics)
mikesr86
Car: AE86 Sr20det swap
i had to remove the head on my sr20det redtop again after just doing my head gasket and my 4th piston has all of these little dings on them...they were not there before I installed the head...any ideas what could have caused this? am i screwed? these pistons are wiseco 87mm...
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Detonation.
Let me guess, exhaust side?
mikesr86
actually my exhaust cam broke...where do i go from here...replace piston? what should i do?
Seishuku
Well, it doesn't look too bad, you could probably polish it out and keep using them.
It really depends on how hot it got exactly, since the ring land may have got hot enough to deform.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
LOL back pressure caussing detonation on exhuast side. When I pullled my stock block apart after running a gt2871 that's what every piston looked like except worse
codyace
Car: S14 w/redtop
I'd personally pull that piston out, and have a machine shop (or yourself if you trust yourself) clean/polish that surface off and reuse it. So long as the ringlands are ok, and it's not detonated into the upper side of the piston (or any marks on the block itself) you should be ok. You probably will have marks atop the head too, these too can be massaged out by a machine shop.
Having a broken exhaust cam also sucks, but be sure your tune is good/timing is set and that all other systems are good before reassembly.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I've seen too many pistons like that with compromised ring lands. I would have a shop look at it and make a final determination once the piston is out of the block. The last thing you want is to spend money trying to polish that pitting out, only to have a ring land break apart on you.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
mikesr86 wrote:i had to remove the head on my sr20det redtop again after just doing my head gasket and my 4th piston has all of these little dings on them...they were not there before I installed the head...any ideas what could have caused this? am i screwed? these pistons are wiseco 87mm...
It looks like it went down the side too, might be fubared. Was there excessive crank case pressure before you pulled the head?
mikesr86
i am going to have to bring this to a machine shop to have them look at the damage...i called wiseco and they said I can purchase a single piston if necessary...
