turbo2nr »
https://forums.nicoclub.com/turbo2nr-u33029.html
Thu May 22, 2008 7:20 am
ok just picked up a set of :arias 8.8:1 .20 over pistonscarrillo i beam rods
only catch there used , but for only 2k, the guy parted out his car. not motor problems the car ran fine.
so what should i look for once i get them?how do i clean the carbon off the piston?what shold i look for in terms of detination and ring lands?
also on the rods, how can i check for warp or stretch?also what should i look for on the bearing surface of the rodsand any thing to check with the wristpin to piston.
thanks
