Hi AntonioG I just read your post and i have a few things to say. I'm running a 91 ka24de as well and ironically pretty much the same setup as your described above. if the only pistons you can find are wiseco then at least you know that they are a good reliable brand, as long as they are installed correctly. if you don't plan on going turbo then i recommend using the 10.5:1 pistons. this is only a bit over stock (9.5:1) for your original pistons.
my set up consists of this:
11.3:1 compression ratio
E85/flex fuel
brian crower stg. 2 cams (264/264)
modified JWT tune running SR injectors
4-2-1 header
and a few other small other things, but that's irrelevant
now, my set up is a bit extreme for what you're planning but i'v been down the same road as you're about to take so this helps you .. not me haha
Pistons:
the wiseco 10.5:1 pistons seem very well designed and i have no doubt that they will clear your BC stg. 2 cams b/c the wiseco pistons have clearance notches machined into theme for valves / large cam lift. I'm running SOHC pistons that are completely flat top and don't have any fancy valve clearance notches. so your pistons will be fine
fuel and tune:
you can actually get away with 91 octane fuel. for the longest time i ran 93 oct... but that's b/c i have higher compression. the combustion chambers were designed with detonation resistance in mind so that's a plus, but i still have detonation here and there sometimes. Honestly, it wouldn't even waste your $ for a tune unless you want just a couple more HP, b/c if you have everything set up correctly it's going to run nearly the same. trust me on this, i made plenty of usable power off of a stock tune. . it's not necessary to convert to E85 with your set up, it's not going to be as extreme as you think, but it should be a bit more peppy.
emissions:
you want to keep your EGR, i made that mistake and i regret it (helps with detonation resistance). trust me, it's not going to hurt that much. Make sure you triple check that you won't have any vacuum leaks after you delete the emissions, you're motor WILL run like crap and probably melt if it's bad enough. make sure you don't delete you FPR, you need it.. don't remove your 02 sensor either. i'm not trying to be rude, i just don't know how much you know. better safe than sorry, right ?
head gasket:
deffinately worth spending the extra $ for a metal head gasket, so good on you! the extra cylinder pressure will put more strain on it so it's smart to beef it up.
headers:
good, even the ebay ones work quite well and they are cheaper. i know a handful of people with them. ebay turbo headers suck btw.. i'm just referring to the N/a headers.
extra advice:
invest in a wide-band 02 sensor, it will save your a**. trust me on this.
you'll want a better flowing intake, if you don't already have one.
after all this is said and done you might as well get your head ported and polished ( i can do this, pm me for more info)
you can also just pick up a used block for like $30 and have better luck with it haha
good luck and lmk if you have any other questions!
