oh really? I would suspect that honing wouldn't be as much as boring of course. But would that also have to be sent out to a machine shop to do, or would a competent mechanic be able to handle this? and just curious, whats the ball park on honing for say a 86.5mm piston, since it isn't oversized by much. thanksGripR wrote:you don't have to bore it, it's not a huge gap you can hone it.
you have cp pistons and replaced the bearings, what kind did you put in? and yea the sizing i have no clue how to do, guess i'll do some research on that also.180fan wrote:If you've got the engine apart, replace the bearings. You'll be glad you did (assuming you did the sizing right lol).
nice write up 180fan. considering I don't have the engine apart, and all this bearing tolerances seem to scare the living crap out of me, should I just leave it alone? I'm not really looking to really go nuts on the hp, and I've read that the stock bottom end besides the piston rings are pretty good already.180fan wrote:Look at the bottom of the block and the front of the crank.
On the block: You'll see 5 numbers ranging from 0 to 3 or 4 I think. There might be a letter in the front but it's on a flat recessed part of the block. Write those down.
On the crank: From the front you'll see two sets of numbers, 5 at the top and 4 below the 5. The 4 numbers are the bearing grades you need for each of the rods. Left to right corresponds to rod 1 to 4.
grade school math: Take the two sets of 5 numbers and line them up so the left hand side numbers from the block are above the left hand side number from the crank. Now add downwards. Ex: block reads 12321 and crank reads 01232
so you'd get:main 1: 1 + 0 = you need grade 1 bearingmain 2: 2 + 1 = you need grade 3 bearingetc. Get it? Using one size bearing for a motor that needs different sizes unless it's been main had been line bored and the crank uniformly cut is a really really REALLY bad idea.
haha "behoof," I actually had to look that work up . Anyway, I was just about to leave the bearing alone since I don't know much about it and I believe they are still in good shape, But since you mentioned it, I'll put some more thought about replacing them out. They just have such crazy tolerance and whatnot and picking the wrong one can screw everything up. Since the motor is being working on by an ordinary mechanic, I'm not sure if leaving it up to them is the right choice. And with sending it out to a machine shop, it would be more money.zippitta wrote:As for the question about the bearings, Yes, replace them. They are relatively inexpensive and it would behoof you to go on ahead and replace it while the motor is apart.
ah I must of understood that wrong then. lucky I won't really have downtime on it sinces its a spare motor, so I'll have plenty of time get all the facts/ spec etc down before I delve into this project.GripR wrote:you don't have to bore it, it's not a huge gap you can hone it.
