r34 gtr wrote:Just purchase someone's short block on here for cheap, or throw some new pistons in it. Even with all that damage, you aren't looking at anywhere near a grand in parts. MAYBE 600 if you bought some CP pistons, but if you just purchased some new CA18ET pistons you wouldn't be out more than a few hundred.
I'm looking for pistons now also, so this thread got me thinking..I can't seem to source Nissan OEM CA18DET (cast 83.5mm) new pistons anywhere.
Wiseco pistons have squirter clearance issues (but do the forged units even need the cooling from the squirters anyhow?)
JE pistons are direct fit, but @ $600.00 a set.... (ahem)
I started looking into the CA18ET pistons, and they are low compression cast units, that seem to be swapable. Nissan has a listing for the ca18et standard size (83.0mm)
Well then I stumbled on ITM pistons, which are even cheaper @ 138.00 a set with rings on E-Bay. I know these are Ebay items, but from what I've been able to dig up, these pistons come in several popular parts counter re-ring/piston kits, and seem to be high quality from the reviews on other online Mitsibushi and Toyota forums.
Anyhow, that being said... the ITM part number for the CA18ET (cast 8.x pistons) in a .5mm overbore is ITM-RY6420-020
Cheers
