Pist'n Broke!
boost infested
Car: cars, chicks, food, and .....
ah... too fast...... toasted piston #3, boost spiked to 18psi. ohhhhhhhh well....... its time to park her :arco:
if you have a piston with rod let me know. thanks.
will be back later,the careless one :arco:
ps: should i just replace the piston and drive it again or park it and save some cash to buy some forge pistons?
red240ne
Car: mmm...donuts
just replace that one piston and throw it back together. figure out why you're spiking too, and fix it.
boost infested
yup, the deltagate is the main problem..... i will get that thing checked.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Hehehehe...fun.
I did the same, to #4.
I replaced just the piston...left the bock bolted to the transmission...removed the head, pulled the oil pan, and pushed the piston/rod up out the top.
I popped a used pisotn back in, and even reused the HG...it ran boosted for another 5-6 months, then I put it in my S13 daily driver for the last 7 months (N/A)...it still runs like a champ, but ticks and burns a little oil from that odd piston.
It's now sitting in my garage as a spare, now that the S13 has it's original motor back in it.
Anyway, it has been done succesfully before, but "proceed at your own risk!"
- Brian
boost infested
oh i am not new to poping pistons... i blew 3 pistons in my 91daytona shelby before i went and got some forged slugs. LOL
klattr1
Car: GT42R powered S14/KA
I have a set of stock pistons and rods if you are interested for cheap. Other wise, the cheapest set of forged pistons can be had for $489 from ka24de.com. Just remember though, forged pistons will take a crap also without proper tuning. Get rid of the Deltagate and get a Tial!
boost infested
Klattr1 please email me at [email protected]
the cheaper the better. they are in good shape?
klattr1
I emailed you.
NateDogg
If this is more than a temporary solution, I'd recommend honing the bore again and put the slug in with new rings. This will get you a proper compression and less oil usage than just throwing the used **** in a smooth bore.
red240ne
Car: mmm...donuts
Yea, you should hone it. Otherwise, the rings will never seat.
boost infested
not broken anymore!
i knew something was ****ed up. it was still pulling same amount of vac', it wasnt burning any oil, #3 plug was soaked with fuel(when i pulled all the plugs last nite). I AM THE LUCKIEST SOB RIGHT NOW!!! ITS MY O-RING ON INJ #3. the lower o-ring was ripped so fuel is constantly feeding into cylinder #3!!! i did a compression test and the numbers are dead on all the way across!!!!!!!!
i guess 19psi ripped opened the damaged o-ring.
lucky sob.
Drift Machine
Car: 1991 KA-T 240sx
Damn you are one lucky MF'er.
Prok0
Damn you sure lucked out..
boost infested
i am new to these side feed injectors. god damn these side feeds LOL!!
thank,LSB
MaxType 240
Car: 1995 S14
Another one to the list of poeple w/ torn o-rings (I'm on that list too) :) I didn't lube them prior to installing the injectors...
Fix that WG man!
boost infested
i did lube them o rings, its one of those things. yes i will fix that wg.
brage
Buy my 50# injectors in the classifieds and go top-feed ;)
-jeff
boost infested
i've got some 55lbs top feed and a alum' rail, the rail just need to be machined.
thank jeff
brage
cool :) What are you using for fuel management ?
boost infested
right now, the fuel setup is 370cc, 255pump, and emanage.
TrunkMonkey
Car: 2000 Lincoln Navigator
boost infested wrote:not broken anymore!
lucky sob.
i'm glad it's an easy fix...
...now if only refocusing my eyes after reading this was just as easy :( .
-demetrius
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
LOL ^
NateDogg
Hahahaha glad you got it fixed!!
