Chaotic_Warlord »
https://forums.nicoclub.com/chaotic-warlord-u26051.html
Sat Mar 26, 2005 9:51 am
ok, did you go buy a wiring harness or did you hardwire it in. What model Pioneer head do you have and did you wire it all up yourself. The reason I ask is because iI have a Pioneer headunit, DEH 7200, and my headunit works just fine. The only thing I can't figure out is how to wire up the power antennea. I hard wired it in because who ever had the car before destroyed the stock wiring connections so I couldnt use a wiring harness. DO you have power to the headunit? If so are you sure the wiring is correct? I've done many a stereo install, with and without harness', so if you have the wiring all backwards the speakers wont get any sound at all. Also are you absolutely sure the pioneer headunit works, test it in another car and see it is sending a signal to the speakers. Check out the wiring diagrams in either the FSM or a book like chiltons to make sure your colors are wired in sync with the harness. Also check to make sure all your wiring is tight and your connections are complete.
