nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Mon Mar 15, 2004 1:45 pm
I'm not sure about you, but besides being in pretty bad condition (considering my car is an '01), that silver pinstripe isn't working for me. So, here's the question: is there any particular process you would/should use to remove it?I ask because I obviously don't want to mess up my paint, and I don't want streaks or anything.
I did a little test area this afternoon. Using a blow-dryer, I heated up an area where it was coming up a bit for 30 seconds or so (til it was hot to the touch), and then started picking at the point that was up a little bit already until I could get some grip, I then pulled a couple of inches off (it's at the end, so I don't have some random piece off), then used a rag with some spot car-cleaner on it to get the glue off. It came out really clean, so I think that process would work as long as I take it nice and slow like I did and heat it up real well, but I figured I'd check with the experts first. The expert in this case being NISTECH, as I assume you would know what possible effects this removal would have on the paint. TIA!
