Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Fri Oct 19, 2012 9:13 pm
A trick I've found for getting those pesky upper ECU screws out - is to use a small ratchet with an extension and driver bit in the correctly sized socket to get it started. This allows you to put pressure on the screw to hold the bit in the head with the heel of one hand pushing the back of the ratchet - while twisting it with the other hand on the ratchet's handle... I've pulled a lot of junkyard ECUs this way and it really helps.
Heath
