pinout for stock RB20 maf so i can test it?
LeX
Car: 2002 Nissan Maxima 6spd
I don't know which prongs to check and i can't find a pinout anywhere.
Trying to check if my MAF is bad. where can I find info
rbspitfire
i cant remember off the top of my head, but i think there are 2 white and 2 black,one white wire is you constant(12V), one is ground, one black is return signal(0.3v key turned on, car not running, around 1.1v idling) and the other balck is a ground......just start probing, one sould have around 1.1v at idle, if the sensor is getting 12v and not sending anything out, then its bad.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Old post but the information I needed.
When I try to start my motor with the MAF on it wont start. It'll barely pop at all.But when I start it without the MAF, It'll start right up without hesitation.But without the maf it doesn't like to be Rev'd
I haven't tested it as yet, gotta wait untill next weekend. I'm also going to swap it with a RB25 MAF. From what i saw on the RB replacement thread on page 3 I have the same part number on my MAF.
Or maybe do I have the wrong MAF??Are the 20 & 25 MAF's the same?
By the way, I have a RB20DET if you didn't know.
Found this on E-Bay.Is this a RB20DET MAF??N60
J60 (22680 02U00 A36-000 J60)Because this is like the one that I have:
Modified by Sil240 at 6:05 PM 2/19/2007
Sil240
Does anyone know if the RB25 MAF and the RB20 MAF are the same??
Little bit of help??
