Pinion angle
Dragon_lowrider
Car: 00 altima
Can anyone tell me the stock pinion angle on a 4 cylinder 2wd 5 speed, I cant seem to find it in the fsm or anywhere
It depends.
The pinion angle should be between 1 and 3 degrees pointed down from parallel to the transmission (or the front driveshaft on a 2 piece drive line.) What that means is the pinion could, under certain circumstances, point up.
Basically, it should match the trans output, which is never 100% straight. The rear shaft should be angled down slightly.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
correct. Get a cheap magnetic angle finder if you don't already have one. The 1-3 degree difference accomodates axle wrap on the leaf springs.
Dragon_lowrider
Car: 00 altima
Thanks guys, I have the angle finder, and I'm 4 linked, so no axle wrap will be happening, i was close when I replaced my upper links, just dont want to blow anything apart, again thank you
