Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Mar 30, 2003 9:03 pm
From Road and Track:"I have a 2001 Mustang Cobra, which, after a few months, developed a ping noticeable mainly between 3000-4000 rpm. The dealer tried a few things (finally a chip reprogram), but has not been able to solve the problem.
Ford has now taken the position that some pinging is normal and has given up on trying to solve the problem. I find it hard to believe that pinging is normal, and believe it can cause long-term damage.
Any suggestions?Richard ThompsonCampbell, California
Detonation is not normal, and Ford did not develop your Cobra with any detonation in mind.
The key clue is something changed after a few months. With performance cars, this is inevitably something the owner modified. Equipment substitutions as innocuous as an air filter can upset the touchy computer calibration sufficiently to cause pinging. Common culprits are open-element, cone-shaped air filters (hot underhood air), aftermarket mass air meters (incompatible calibration, a very typical problem) and open-element breathers atop the valve cover (admits air downstream of the mass air meter and upstream of the throttle, thus leaning the mixture).
Step one is to remove any aftermarket items, returning to absolutely stone-stock condition. This really ought to end the pinging. If not, run the fuel tank low, fill it with premium and dope it with octane booster. If the pinging goes away, you likely have a fuel problem. Higher-octane fuel — the 91-octane gasoline in California is borderline in some applications — ought to stop the castanet rattling. If that doesn't work, then you really may have a hardware issue (clogged injector), although these are very rare in cars with less than 125,000 miles. More plausible is carbon buildup due to rich running from some other problem. Also, you can — and probably should — go one heat-range colder with the sparkplugs."
