Libraman2k1 wrote:After bringing my car to an infiniti dealer in louisiana, he replaced 2 lifters and 2 coils and then this pinging/clattering of the valves began
They actually pulled the heads and replaced two lifters!?!?! When you say coils, you mean the spark plug coils? They're not prone to failure.
You need to make sure the plenum, runners, EGR valve passage going into the plenum, etc. are cleaned back to as-new condition. You should definately check your knock sensors... the dealer should have checked it with Consult. Make sure the timing is truely set at 15BTDC. The CAS adjustment is very sensitive. Also, have the injectors checked (power balance test on Consult) and flushed if it's been a while. If you aren't familiar with the "power balance" test search for it with the red button in the upper right hand corner... there have been several threads on this lately.
One other thing to consider... new spark plugs? Only use factory plugs... bad results with anything else!
Heath
