karism »
https://forums.nicoclub.com/karism-u95228.html
Tue May 06, 2008 11:23 pm
Morning Guys (and Gabby)
I have a little problem currently, not a big one.
Let me give some background first:I`am running 93 Octane Unleaded , Timing is set on 15Deg BTDC. NGK BCPR6E11 Plugs. New Fuel filter (E14),and new High Flow Bosch pump fitted.I was driving around earlier this week, and I heard the pinging(pinking)It will ping, and then it will go away, as the timing is obviously retarded to save those poor pistons.Decided to go and buy a boost gauge, and have a look what the engine is boosting. Fitted the boost gauge on, and the first reading it gave was 10.6 PSI. Oh noes!!!!Danger to manifold!!!
Let her cool down a bit, and then I adjusted the actuator rod , to lower the boost a bit.
I got some conflicting answers, but as far as I know, it should be boosting 8 PSI?(please confirm)
Went for another drive… Vrooom,vroooom,VROOOOMMM..Krrrrrr. Ok,so now the gauge was showing 12PSI.Damnit!The thread on the rod is clockwise tightening on both sides idiot!
Got it turned down to 8.5 PSI for now.(my hands hurt, they are burnt for pete`s sake! )Any ideas why it will be pinging? Should I turn the boost down more to 8PSI,or lower?Please help!Thanks Karis
