TheOne »
https://forums.nicoclub.com/theone-u18820.html
Fri Oct 05, 2007 9:30 pm
it is called a pilot bushing/bearing remover and should be rented with a slide hammer if it doesn't come with 1, the 1 from autozone worked great.
now if its the automatic trans converter bushing, do not use the pilot bearing puller as you will more than likely just break it.
