S13Ryan »
https://forums.nicoclub.com/s13ryan-u167049.html
Tue May 10, 2011 10:10 pm
So I just found out ever since I put my rebuilt KA in my car about 20,000 miles ago it had a pilot bearing.
Since the rebuilt motor has been put in its been through 2 clutches, and now the transmissions done.
So I went to install the pilot bearing today and it wasn't going in very easy but I got it in. I made sure the pilot bearing would slide on and off of the transmissions input shaft before I installed it.
Then I went to push the clutch alignment tool in to check it out and the clutch alignment tool wouldn't go in, the pilot bearing whole was too small.
I then chiseled it out into pieces and went to nissan to get a new one, and measured the diameter of the outside of the pilot bearing and its at .812.
Then I went and measured the inside of where its supposed to go and its at .752.
What's going on here? And what could I do? I have access to a lathe that I could trim it down some, but I'd rather know why its like this.
