Pilot bearing/bushing
Salvadorian561
Car: 96 240sx se
hey guys i just got an RB20 auto but i have a manual transmission and I got the z32 na pilot bushing will i need anything else like a converter? by the way the motor is in a s13
fast_s14
Car: 94 300zx
no converter with the manual trans, all you will need is a manual flywheel and clutch.
Salvadorian561
Car: 96 240sx se
Alrite thanks im just having trouble removing the pilot bushing rite now
lazyboi444
Car: 240sx Hatchback
If I'm not mistaken, We(Autozone) sell pilot bearing removal tools. Looks kinda like snap ring pliers on a large scale. U can rent the tool also.
eh?
I know for sure there is a flexplate adapter for RB25 auto engines. It's gotta be removed to install the flywheel. I guess it's the same for RB20's and I'm guessing since it's an auto and you are having trouble removing the pilot bearing that adapter needs to come out.
Salvadorian561
Car: 96 240sx se
what adapter? I tried the tool but no luck and I have the 300zx n/a pilot bushing but when i compare it to the whole on the motor it looks like its just goin to sit in loose and not grab? the motor was used with RB20 auto transmission but im using the 5speed im searching everywhere but when i find something its different??
Carryl
my rb20 was 4wd and auto.......only had to pull the auto bushing....or rather hammer and chisel it out... reused the auto dust plate.......should be noted that i had my pilot bushing turned on a lathe (measured the crank and pilot shaft) but that was only because i couldn't find one on the island (st.Lucia)....
Salvadorian561
Car: 96 240sx se
but im trying to put a manaul transmission ive seen a forum talking about flexplate adapters. well im goin to nissan to see if i can get one for a ka and use it
lazyboi444
Well i know there is a guy on here who did a RB20 auto swap long back. Name is ACECOOL on here. Think he did RB20 mated to a KA transmission. Think he used the KA pilot but not for sure. Shoot him a email.
Salvadorian561
Car: 96 240sx se
Ok thanks
eh?
All rwd nissan pilot bearings are the same
Carl H
gotta remove the converter bushing...its pressed into the crank and only way ive gotten them out is with a slide hammer...had to do it on my vh swap.
here is a pic of what needs to be removed/installed...pilotbushing on left needs to be installed and converter bushing needs to be removed on the right.
S14eva1
Car: S14 aka "The black bandit"
since we are on the transmission subject....
Is the rb25det auto transmission the same as the z32 TT auto? besides bellhousing...
2d-ink
THis is how I removed my Pilot bushing, pack the Inside of the bushing with grease use heavy thick grease, then use a bolt about the same size as the pilot bushing, Put the bolt in there and thread it. As the bolt is moving in it pushes the grease out and slowly pushes the pilot bushing out.
Salvadorian561
Car: 96 240sx se
Ok thanks guys apreciate it but it seems that the one on the right is bigger then the new one? doesit matter if it just sits in there? heres some pics my look a bit thinner though
Modified by Salvadorian561 at 9:58 PM 12/1/2008
