Pillow tension rod = lower control amrs?
Thesil
Well, with all this snow we've been having here in the midwest, i've found my self better aquainted with the curb near my house!The damage is not slight either... i bent the left side lower control arm.
My question is does JIC make a lower control arm aftermarket peice? I remember reading something about it however on their site it says pillow tension rod, is this not what I am look for? can someone please point me in the right direction.
barrigas14
tension rod is the front of the car. the control arm is the rear.
Thesil
Are you sure? The people at midas told me it was the front lower control arm. http://www.pdm-racing.com/prod....html
Thats what I need but for an s14
Exar-Kun
Car: 2005 350Z
look at the suspension FAQ< theres a nice diagram that shows the entire front and rear suspension :)
the tension/compression rod or t/c rod is seperate from the front LCA, which you do have.-chet
JJ240
Car: 95 white 240
You can pick up a pair of new nissan LCAs with whiteline sway bushings already pressed in from PDM if youre looking to upgrade. If youre LCA bent I would be suprised if you didnt bend your tie rod as well
-Edit- Yeah my bad just saw someone already posted the PDM link.
Dori Dori
Car: Cars of course
And an fyi, aftermarket LCA's are very expensive.
JJ240
Car: 95 white 240
wow edited that post 3 times to fix mistakes, and now I come back and see I wrote whiteline sway bushings...I need to not make posts past midnight because I must not be able to think.
