pignose transmission
slidewayzinak
Im sure this has been covered, but i could find any search results. is the pignose transmission any different that the newer s13 5speeds. im doing a manual swap on my s14 and come across a good deal. and will there be any issues using a s13 transmission, the sticky on the swap didnt give a distinct answer.
180fan
Car: 89 fastback
Nope but if this is going into an s14 you'll need to have a resistor across the sensor that's at the bellhousing on your s14 transmission to keep it from tossing a code in your face.
nightkid86
Car: 97 S14 SE
Or you can just drill a hole to mount the CAS
slidewayzinak
its an early 95 so its obd1, does that make any difference
