s13drifter88 wrote:In answer to the engine management question Nistune would do everything that it seems youre looking to do. Now I have no experience with the SDS system that was spoken about above so I cant judge it or really compare it. I myself have gone the rom tune route with Jim Wolf Tech but I do have 2 good friends running Nistune and it sure seems to a great job. I do like the idea behind Nistune as well because of the features it provides without the high cost of a full stand alone ems. For majority of the street applications I think its more than enough but thats just my 2 cents but Im open to new ideas so feel free to correct me.
this is my semi-experienced opinion:
I think Nistune is very capable and was my first choice due to price, features and real time map tracing. If you're on a ~$500 budget, Nistune should be at the top of your list!
Why I say this: I have a Romulator plugged into my factor ECU, if you search for threads started by me, I struggled to get the car to idle properly, pass emissions in Ontario, has spark blowout, etc... I was fed up with the amount of time it took to something simple, like update the fuel map.
First, I'd have to log a run using an external logging tool (Zeitronix in my case), guess what part of the map was being accessed, update the fuel or timing amount and then update the romulator. That's a 45minute procedure... After you update, you need to log another run and see if you corrected the problem....
If I had Nistune, I could jump into map trace mode (whatever it's called), find where it was accessing the map at the RPM and load, modify on the fly and be done with it. Second, with Nistune, I could have adjusted my idle AFR sooo much easier! There's a set procedure to fine tune your injectors so you idle at 14.7, have a base value then adjust your fuel map and timing.
SDS : My side of the story
Going to SDS was a no brainer for me, I found a used EM-3F system for less than Nistune new. (racetech.com: The EM-3 knock sense parameter will only adjust from 1 to 16, whereas the EM-4 can adjust from 1 to 32. The EM-3 cannot support the new nitrous retard, and A/C aux input features. The EM-3 does not have a 5 volt tach output on the main harness connector.) Even if I order the 2 missing sensors and resistor pack from Racetech, I'm at the same cost of ordering Nistune with software... which I was prepared to do.
What sold me on SDS was reading the installation manual and getting started guide made sense. The company posted EFI theory on their website that was down to earth and understandable. Second, my Silvia is a 3rd car, if it blows up, who cares [edit:] (not me), my son goes to bed at 7PM and I get to wrench on my car without worry for 3 hours... I wanted to simplify my setup and in a few years I'll only have to pass a two speed idle test for emissions, no load, no nox testing, no worries! =D
