piggly rich wow!!!!!!!!
crazygrk3
i have jsut got me a 92 coupe with a ca motor in iy and abotu a month ago and its running way to rich so when i took a look at my o2 sensor only of the 3 wire wat connected just the blakc one the other two wite wore were cut and as i follow the black wire it seems to be wired into the harness could it just be a simulaotr so it doesnt trigger the check engien light ???
damesta
WHAT???? Are you trying to ask a question? If so, what is it?
themadscientist
Good lord man, grammar and spelling go a long way in helping us understand you. Try that one again so somebody can lend a hand.
Secret squirrel
Car: 1990 240sx w/ ca18det
**snakes voice from the simpsons** PERIODS DUDE....PERIODS!!!
SS
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
If only the black is connected..then your piggly wiggly (WTF!!??) 02 sensor is not connected.
Replace the 02 sensor, and fix the wiring. The wiring was cut for a reason, probably a blown 02 sensor heater...
Good Luck
