pig tails <licese plate lights> problem
keysersoze
I am in Virginia, with a 91 240sx coupe. I have to get it inspected, and the pig tails don't work..I checked the bulbs...they are fine...I also noticed that the rear side lights aren't working either. If there is a fuse, where is it...I have the Chilton book..no help..I read the manual...no help.....please tell me how to fix it...I can't drive around much longer without an inspection sticker....$60 dollars plus $45 dollar court processing fee if I get caught...... Immediant help would be greatly apprecated...
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
are your front sidemarkers working? If they aren't than its probably a fuse. Just check your fuse box near/above your left side foot.
keysersoze
yes...the front side markers are working....and I checked all the fuses in the box at my left foot
nnkfws333
Can you check to see if any of the wires are cut or at least recieving any power?
keysersoze
I will do that today, and get back to you..
keysersoze
I pulled the bulbs out, and checked for current..there was...I feel stupid . It was just that the bulps were blown. The wierd thing was the filliments were intact...the blow was somewhere in the base...so when I pulled the bulbs to look at them, they appeared fine.....thanks for your help, though
