pig rich
bigwrig511
Car: 93 s13 sr20det
I just put a sr20 in a s13 and drove it for the first time. The car ran great untill i got on it. I hit the gas in first shifted at 5000rpm in to second the car started to go then then bogged and started runing rich. Now the car runs so bad It was hard to git home. Is it the maf?
RMiller
Car: BBQing
boost leak. check brake booster line, it can pop off.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
i would say boost leak... check all connection. brake booster too. let us know what you find out
bigwrig511
Car: 93 s13 sr20det
its rich at idle not just in boost. Its so rich it doesnt want to rev or idle.
RMiller
Car: BBQing
A big boost leak will make it run bad all around. It will have a hard time idling since the maf will be detecting a grossly different amount of air, whether more or less, than is actually making it to the engine.
-boost leak-o2 sensor gone/crapped out-fuel pressure regulator stuck-lack of good grounds-random unplugged plug
I put this in what I think is the order of decreasing likeliness.
bigwrig511
Car: 93 s13 sr20det
thanks for the advice. I will let you know what it was when i find the problem.
vlow1210
can also be the coolant temp sensor
RMiller
Car: BBQing
vlow1210 wrote:can also be the coolant temp sensor
Yeah it can be many things, check the ones you can check without having to buy stuff, because then you may end up buying a grip of parts you don't need.
Unplug o2 sensor, see if anything changes; look for boost leaks VERY CAREFULLY especially if you use any "accordian" style tubes that can crack in the grooves and be hard to see; check for continuity w/ a dmm, look for visual problems, check fuel pressure. First pull codes, but that's gimme.
TWAN
Car: 240sx
Yeah, that coolant temp sensor got me too. But it does sound more like a boost leak.
boost_creep
Car: 92 sr powered coupe,06 Spec V
im running rich too..but not as rich as our friend here..i just wanna ask rmiller a question...u said to unplug the o2..hot or cold?what should happen?...mine doesnt change the slightest
bigwrig511
Car: 93 s13 sr20det
I found the problem. It was a boost leak. The car runs great now. I have put about 200 miles on it with no problems. Thanks for your help.
