piece o ****e speed governor
eastcoastchaos
Car: 95 240sx
i've read the faq on how to rid my car of this governor but it did not entirely work. they say to snip the yellow wire w/ the green stripe, the 8th one down on the left of the ECU. i did that and took her for a run. it now tops out some where around 120. it used to be about 114. it sort of worked but i still have about 2k to go before she tacks out in 5th gear. any info is greatly appreciated. thanks
EnzoRWD
Car: 1997 Volvo 850 T5
unplug last two sensors from transmission. (two most rearward) i believe called (O.D. and Top position). they tell the comp ur in 4th and 5th gear. get rid of that, no more limiter....
eastcoastchaos
Car: 95 240sx
will my speedometer still work and can i plug them back in if stuff goes wrong? thanks
nightwalker
Car: 240sx
are you running a ka or SR?
eastcoastchaos
Car: 95 240sx
it is a ka24de
eddiec
Car: 91 S13
just unplug. if not working the way you want then plug back in. no harm.
cutting wires, p.i.t.a. to fix back.
also heard of putting a switch in line with one of the sensors so that it could be done from the captains chair on the fly. i think it was the speed sensor.
nightwalker
Car: 240sx
if it's a KA, go get yourself an AUTOMATIC ECU. They don't have speed governors. I know for the S13s, and obd1 s14s, you can just plug the new auto ECU in, and VIOLA! no speed governor!
I've been using an auto ecu for the last five months, racing, regular driving, no problems. Way better than cutting wires. Check your local junk yards. Last I heard, they fit down pants pretty easy!! :D (er...I mean....):rolleyes
bcuz
nightwalker wrote:if it's a KA, go get yourself an AUTOMATIC ECU. They don't have speed governors. I know for the S13s, and obd1 s14s, you can just plug the new auto ECU in, and VIOLA! no speed governor!
hahahha :pface
eastcoastchaos
Car: 95 240sx
i don't know what happened but it may have fixed itself. the needle was well into the trip odometer thing and it didn't cut out. maybe my 40 is magic. but thank you all for your help, if she starts *****in or cuttin out again i might go w/ the auto ECU. thanks again. peace
