Understand that the 1 point increase is 0.1 point [1%] of octane increase.Marketing gargon designed to confuse.
No matter how much you use, even 10% by volume, hard to add even 1 octane, as they have already tricked up the fuel.
Toluene or p/m- xylene is the product that is most effective and least cost per real point increase if you buy in 55 gallon drums and just add 5%........1 gallon per tank full.
http://www.elektro.com/~audi/toluene/
10% ethanol already adds 3-4 REAL points to basic gasoline, so you can see how bad the basic gasoline without ethanol really is!
"the F1 racers did not use 100% toluene, but 84%. The other 16% in their brew is n-heptane, which has an octane rating of zero. The reason for this strange combination is because the F1 rocket fuel was limited to the rules to being of 102 RON octane. The n-heptane is "filler" to make the fuel comply with the rules. "http://www.tundrasolutions.com...-fuel/
At $5 per gallon [toluene] you can add 1 REAL point of octane for 25 cents per gallon of gasoline, using over the counter octane boosters would cost you $2-$3 per gallon of fuel upgraded.
