pictures of big three upgrade??
bronson96792
Car: 2007 altima 2.5s dark slate
i read the faq on the big three upgrade, ordered about 12 ft of 1/0 Black Power/Ground Wire from knukonceptz (is that enough??) which should come in tomorrow. for the people who already did this do u have any pictures of where u ran the wires??
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
bronson96792 wrote:i read the faq on the big three upgrade, ordered about 12 ft of 1/0 Black Power/Ground Wire from knukonceptz (is that enough??) which should come in tomorrow. for the people who already did this do u have any pictures of where u ran the wires??
with the 2.5, 12 ft should get you there, depending on where you ground your upgraded negative battery terminal to chasis wire. With the 2.5, you need a bit more due to the awkward location of our alternator.
bronson96792
got any pics doc??
rjdmmfl1
yeah, but its of the 3.5 negine... yours won't look anything like it... I'll get some better ones after the audio upgrade tomorrow
bronson96792
thanks doc... u still running the ba pro 60's??? i picked up a pair about a week ago
bronson96792
btw doc did u use a fuse for the alternator to bat+ ??
bronson96792
would i be able to ground the neg bat on the little bolt over here??
or should i run it up here???
rjdmmfl1
bronson96792 wrote:thanks doc... u still running the ba pro 60's??? i picked up a pair about a week ago
nope, I blew my Pro 60's 2 days ago...tried to pump too much midbass to them...
bronson96792 wrote:btw doc did u use a fuse for the alternator to bat+ ??
no, no fuse between alternator and battery, just keep the stock one, and add another one to the stock one.. i.e. you will now have two power cables from your battery to your alternator...the factory one with a 250 amp fuse, and that goes through the starter on the way to the alternator, and the new 0 gauge one dircectly from the battery t the alternator
yes, battery ground upgrade can be ANYWHERE on the chassis
bronson96792
thanks doc i just got home from work gonna start on it today and ill take pictures with my iphone
bronson96792
i bought battery terminals from knukonceptzhttp://www.knukonceptz.com/ima...0.JPG
i go 2 of these i installed the negative one just fine, but i dont know how to remove the positive terminal with the fuse box on it grr.....
and i cant find a bolt to fit the hole in the first pic..... i know theres already a bolt right above it but i just noticed that its on plastic
Modified by bronson96792 at 10:47 AM 10/4/2008
rjdmmfl1
Just curious as to whether or not you ever finished this??? I don't think I have a picture of all three parts of my Big 3... but I have a few...If I can ever remember to take my camera with me next time I'm under the hood, I'll get closer shots... but for now, heres a few pics...
Positive battery to Alternator... 0 gauge, blue wire... its hard as sin to get to the Alternator on the 3.5 due to its placement on the inferior part of the engine!
In this picture, you can see the dark grey 0 gauge wire coming off the negative battery terminal, and a light grey 0 gauge wire cruising along the radiator hose whihc goes over to the engine ground.
Again, I will have better pics up later!
