Pictures in message
AZQ45
Car: Q45, G35, My 3 sons, hockey, snowmobiling (when I can)
How does one post pictures in the message? The vB Code help on the IMG coding was a little confusing as I do not have a http address for the pictures (to my knowledge).
Also, where are members posting their rides?
Thanks for the help.
:confused:
BIONICQ45
Test
BIONICQ45
Compliments to Heath (Q451990) for the pic.!!
AZ, I attached the image from a disk using the Attach file feature below.
BIONICQ45
More specifically.. it is below when you are posting.
Stoneage_Turbo
Car: 1994 Caddy Deville 4.9
Just about anything
sites picky about sizes of stuff on here no bigger than like 400x400 pixels or something and no more than 204800 bytes
not that im complaining just had to figure that one out myself as i couldnt put stuff in there
Q451990
Hey Bionic - nice car! :ylsuper
Welcome back, Jed (AZQ45)!!!
AZ is gonna be the NICO capitol of the world (Sorry Chally) if I can help it!!!!
Stoneage_Turbo
Just about anything
hey that black q , those arent the stock wheels are they ? they look like 2nd gen stuff , either way , very very nice . definately beatter than the piepans (sorry guys just look at that car )
Q451990
Well, they're stock... but from a '97 - so you're exactly right. Way to know your wheels man! Be safe over there in the desert...
Heath
AZQ45
Hey Hitman et al.
I thought I would post a picture of my Q - it looks almost identical to Q451990's! My wife never even noticed I changed wheels!
My Q is running well...I hear an exhaust shield rattling a little at idle. The AC is working exceptionally well. I still have the g35 on my mind, but when I placed an ad for my Q, I did not even get one call! Unless I get around $4500 for my Q, the G will have to wait until next year.
lonallenq45
Looks similar to mine too (except the wheels are different and the absense of a rear spoiler). OK its the same color.
Rattle coming from a heat shield? I thought this very same thing concerning a different vehicle from a different marque. It turned out to be a self-destructing cat. The element had come loose and was rattling around in the housing. It turned out to be a common problem with those cars. I have never heard of it in a Q, but you never know. Mine only rattled at idle. If you gave it any gas the flow of exhaust gases appear to trap it loose element against the back of the cat and the rattling stops.
Just a thought...
Lon
Q451990
AZQ45 wrote:Hey Hitman et al.
That's a good looking car! :) I took about five seconds trying to figure where I was when I took the pic until I noticed the green paint...
Heath
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
AZQ45 wrote:...I hear an exhaust shield rattling a little at idle.
Just take them off, both of them!!
I was in denial for months and months that the heat shield under the cats was not rattling enough to make noise... was sure it was something in the suspension.
Removed one of them 2 months ago and things got better, then removed the second one last week and... NO MORE NOISE!!!
I FEEL something in the suspension now and then, but never hear anything anymore.
Just takes a 10mm wrench and a little patience... kinda hard to work with if the nuts are rusty, but worth the trouble.
Q451990
But they had to be there for a reason in the first place... I've been able to bend them around a bit to eliminate noises... also had a noise from the exhaust mounts missing a couple of nuts.
Heath
DAEDALUS
Car: 1990 Infiniti Q45
Use a hose clamp to lock the heat shield down. If you're not sure which one it is just tap around with a rubber mallet.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Hey guys, currently the IMG tags are turned on for signatures ONLY (hence, my signature works). Attachments are limited to 400x400 pix. This is to cut down on bandwidth. If anybody wants to change these settings, maybe start a poll?
Personally I don't want to change them. I like having low bandwidth for two reasons. One, is it makes the sight faster, and the other is for dialup users. I am on DSL, but I know the pain of dialup. And I don't want to discourage dialup users from coming to this site because of load time.
But, we will always be open to suggestions. Anybody who has any comments or suggestions, feel free to mention them! We are all ears.
fabiandawg
Car: drums, car, bishez
test
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
EZcheese15 wrote:Hey guys, currently the IMG tags are turned on for signatures ONLY (hence, my signature works). Attachments are limited to 400x400 pix. This is to cut down on bandwidth. If anybody wants to change these settings, maybe start a poll?
I would keep them out of signatures also. What's the point?
Did you just hijack this thread, EZcheese15?
landtodd
The error message says "no bigger than 300x300"
