Onizuka »
https://forums.nicoclub.com/onizuka-u2660.html
Sun Jan 11, 2004 5:46 pm
a note on the T28, I had to modify the oil return fitting, not hard, just a reaming bit and a good drill gun got it done in about 10 minutes. I also had to cut off part of the wastegate-turbine exuast splitter on the greddy turbo extention because the 28 has a small one cast in the exaust housing. That just took about another 10 minutes with the dremel. Then you just slightly bend the water and oil hard lines and it bolts right on :rockon
