Picture of engine components?
aeromark
Car: 94 Q-45
Any one have a pictures/video of a 1994 q-45 engine bay w/brief tutorial? I have a 2" x 3" black box right next to the starter relay that is huming loudly and had heated up to the point that I had to disconnect the negative lead to the batery to stop it from melting down. This was 25-30 minutes after the engine was shut off. Any one have any idea what the component is? Will replacing this component solve problem or is it an effect of something else?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I am guessing you mean the ABS relay?
Check out the service manual for pictures: http://www.nicoclub.com/FSM/
Or this crappy video I made, oops I forgot to cover the ABS relay but I still think that the problem.
All you have to do is go to the stealership get one and gently remove the black plastic cover to replace it.
aeromark
Car: 94 Q-45
My daughter had said the ABS light came on as she was driving home so I'd guess that makes pretty good sense. I'll swap it out. Thank you for your help
