Picture History of CA18DET Head design
tommey
Car: S13 ca18det
There were never a CA18DET with EGR?
All my 4port heads have the outlet but its blocked.
themadscientist
I've never seen one. The SOHC CAs, yes.
float_6969
The USDM KN13 Pulsar had EGR for sure. Others may have as well.
stapes
Car: S12 Gazelle/Silvia
float_6969 wrote:The USDM KN13 Pulsar had EGR for sure. Others may have as well.
Australian N13 Exa had one as well. Front wheel drive no turbo.
Another item that might be of interest regarding this particular CA is the NICS Secondary Butterflies Control System
fitted to S12 Silva. It has 2 vacuum tanks and 3 solenoids. I don't believe this type is fitted to any other engine in
this series other than the S12 Silvia. I have some pictures some where will put them up when I find them.
Stapes
float_6969
Hmmm, I wonder if there are more butterfly valves in the manifold than what I've seen pictures of?
stapes
float_6969 wrote:Hmmm, I wonder if there are more butterfly valves in the manifold than what I've seen pictures of?
trust me there are only the eight, and here are the pictures of the NICS set up.
TheMAN
and since the CA18DET uses the same head as the CA18DE, you can actually see an EGR block off plug on the CA18DET
not that anyone wants to, but I wonder how hard it would be to retrofit an EGR valve into the CA18DET for those in places who are very strict about NOx emissions ;)
float_6969
You'd have to use the USDM FWD over-the-top intake manifold. It's the one that has the EGR feed built into it. I don't think any of the other do.
ska69
Car: 200sx s13 ca18det
pardon me but what's an EGR? exhaust gas recurculation valve stuff? I for some reason happen to have on laying around, albeit just the valve. or is this something to do with fuel tank ventilation? I'm talking EDM 200sx s13 CA18DET
livelyjay
Car: 1987 Nissan Pulsar (CA18DET)
2003 Mazdaspeed Protege
2007 Toyota Matrix
EGR is exhaust gas recirculation. It feeds exhaust gas, through a valve, back into the intake manifold. The purpose being that there is unburnt fuel in the exhaust so to reduce emissions, a portion of the exhaust gas is pumped back through to be burnt again.
240Clarke
Car: 1992 Nissan 240SX coupe
Figured Id post a couple more pictures for image reference.
8Port CA18DET
