- new front shocks
- 2 front lower ball joints
- stainless brake lines
I just put my winter tires on today and got a decent look at what was going to be involved in these 3 jobs but I have no parts infront of me and Ive just never done them before so please bare with me and I can explain with pics
#1, front shocks
Mine are pretty beat lol
To me, I think I have to remove the stabilizer link, take the brake line off the bracket on the shock. Remove the 3 bolts on the shock tower, remove the huge 2 bolts that I pictured, then compress the spring and out it comes?? People made it sound very hard job in the searches I did
#2, ball joints
Ive never had them done, Ive got some clunking in the front and they came with a set of end links I orderred so I figured I may aswell install them if it isnt much trouble. I have a tie rod remover tool that I think may come in useful for this. Do you simply have to remove the 3 nuts on the bottom and them pry loose the ball joint from the knuckle with a pickle fork?? I dont know if taking off the 3 nuts and the castle nut would free it from its home and give room to install the new one. Need an alignment afterwards??
#3 brake lines
I orderred a 3 piece set of brake lines from goodridge, I dont quite get how th kit would installl though, these pictures are of my front drivers side, assuming the passenger is the same. Anyways I get how to disconnect the line at the caliper, simply nuts and banjo. But the other 2 connections Im unsure of.
Where it connects to the shock, is this just placed on the bracket and with some wd-40 and a flat head would just pop off or is that connected somehow??
And where the line meets the body, do you just spin that nut counterclockwise and the fitting would disconnect??
They all looked like regular 0mm nuts to me, do you really need to buy the brke line flare wrenches??
