Pics of S13's with RB clusters..
RB280SX
Does anyone have a pic with of an RB cluster in an S13? I can't find any on this site.
240slidekat
Car: 240sx, 280z, gsxr1000, m3
POOPmouth
Car: The Devils pimp ride
wont let me reigister - dam
Carl H
old pics of my s13 with the gts-t cluster, pita to make work imho.
blk90s13
the pics or the cluster ?
edit never mind the pics wok now
27RB240
Car: 92 240sx coupe
Here's one here, its a R32 cluster, well I believe he took the gauges out of the cluster, and mounted them in the 240sx cluster...........
http://cgi.ebay.com/ebaymotors...QrdZ1
POOPmouth
i dont know about thatmaybe- i v talked with the owner of that carand asked him what he did -
used both 240sx cluster dohc wiring dygramand r32 gst clust dygram - said it took him like 12hrs as for speedometer - he used an electric one - im in process of looking for all info needed to do it - then ill do a write up to be contunied
300Plus
Car: 1995 S14 w/ Rb25det Series II
I made a writeup for the r33 cluster into s14 Its on here and http://www.Racebread.com . so just figure out the s13 side and you are done
Carl H
POOPmouth wrote:i dont know about thatmaybe- i v talked with the owner of that carand asked him what he did -
12hrs to rewire a cluster wtf?you have to be straight up retarded to do that, i did mine in about an hour and a half...
Tictakman
240slide- did you ever do a write up on how to install that rb gauge cluster? would you mind telling me how to wire it up? is that a r32 cluster?
i wonder how close in color matching the wires are between the s13 and s14?
thanks,
Zak
RB280SX
Might have been a pita but wow, it looks so nice compared to the stock one. I'm hoping that someone comes up with a writeup soon .
240slidekat
Tictakman wrote:240slide- did you ever do a write up on how to install that rb gauge cluster? would you mind telling me how to wire it up? is that a r32 cluster?
thanks,
Zak
sorry i didnt do a write upwhen i did it. its a r33 cluster by the way. i just sat there and followed the wires in the back. not that hard but pretty time consuming. the wiring from the s13 to rb cluster is not close. it would also help if you have the pig tails from the rb cluster.
300Plus
thanks,
Zak
The wires don't match color wize at all. unless just by chance one out of the 30 or so wires does.
S13 240SX
Car: 93 Mazda Miata
wow.. how do you guys make that cluster fit? it looks way big...
RB280SX
Your sig is very long . Man..., that R33 cluster in that car is pure sex.
POOPmouth
i also agree - - - ------- i have a r32 cluster - ---------going to try install that one - willl see how it goes -
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
I know this may sound really n00b, but to clarify, I have a 93 S13 with the digital instrument cluster and a Oct-94 GTS-T half-cut, if I am correct, the GTS-T cluster will fit correctly into the S-13 dash? If so, all I would need to do is just correctly wire the instrument cluster.
l0nestar.
Edit: I just read above.
What does the R32 instrument cluster look like as opposed to the R33?
l0nestar
2004 Toyota Altezza
300Plus wrote:The wires don't match color wize at all. unless just by chance one out of the 30 or so wires does.
More or less, you need an R33 wiring chart, S13 wiring chart, and an S14 wiring chart. Use your guide and edit the S14 info and convert to S13. A simple, 3-step process! *ducks* But seriously, is that the logical thought process? I do happen to already posess the R33 FSM & S13 FSM, so I would assume the S14 would not be hard to get as well. I just havent looked since, well, I do not own an S14.
l0nestar.
300Plus
All you have to do is follow the labels on the back of both gauges and right down or label what that wire goes to, then once you have done that for both car and cluster (no matter what combination) you splice together. Thats how it works
