rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Sat Mar 15, 2008 3:46 am
Go to your local tire expert, they will probably tell you that you are putting too much or too little air in those back tires. Use correct tire pressure. Also get an alignment, its a lot cheaper than a MOD and is usually warrantied for 6 months to a year. and of coarse, BUY GOOD TIRES. Falken FK452's are on my Z currently and for the price you cannot beat the performance. Not the cheapest, but far from the most expensive. If you drive your Z as your daily driver you might not want the FK452's, yes they are sticky, but wear comes with grip.
