Pics of my rb25
T4 RB25det
Car: 1995 240
been on here for a while and i have never posted any pics of my setup...so..
setup is like this:RB25DE block and headgts-t transgerrett gt35r with t4 flange, 1.04 hotside ar, to4r compressor cover, q trim wheel, venturi bolt thingytial wastegate3.5 flared to 4 inch downpipe4 inch apex GTspec exhaustEprom tuning software made by one of my freindstop mount mani from thiland-not ssac they dont make a t4 maniintake manifold also from thiland600cc injectorscozmo fuel pumpgtr fuel railq45 900 throttle bodyspearco front mount intercoolertial 50mm blow off valveHKS headgasketgreddy timing belt coverOS giekin lightweight flywheelOS giekin tripple plate clutchand some other stuff that doesnt really matter
The DE wasnt used to be cheaper, it was suprisingly more expensive after all was said and done. the DE block has a better deck design than the DET, the rods are stronger, the pistons still suck, and i cam easily make an RB30 if i choose to blow this motor anytime soon
krayton
engine looks awesome.
but clean that engine bay! and some of the wiring too
nice job though
T4 RB25det
Car: 1995 240
yeah the engine bay is pretty nast right now, for a little while there the fire wall, was doing its job of keeping fire out of the cabin, since the wastegate was shooting straight at it
the wiring is better now also, i am running a GM blow through MAF also to get rid of the pre turbo maf sensor, and all the injector wiring has been run underneeth the intake manifold, the wiring harness has also been tucked
krayton
^good to hear.
ran my wastegate like that too. sounds awesome right there. like hell opening up.
of course there is also a nice spot on my firewall that says differently.
Sky240PWR
Car: 1991 Nissan 240SX
so how much whp do you have with that setup??
MidWest240Collector
How hard was it to wire up the GM blow through, I kinda want to get rid of sticking something in front of the turbo.
T4 RB25det
Car: 1995 240
Sky240PWR wrote:so how much whp do you have with that setup??
high 400si dynoed with a different turbo that was a little smaller hitting consistant 420-425 on a mustang dynoso it depends on what dyno you go to. dynojet would be low 500s i would assume, mustang dyno reads lower tho
the MAF was pretty easy to wire up. i have a diagram on my comp if you want to do it
Sky240PWR
nice numbers, have you ever ran it in the 1/4?
Carl H
makes sense why the engine looks like a rb20 now, the rb25de looks exactly like the rb20det........also explains the lack of vtc.looks good man and the potential to convert to rb30 is def a plus.
T4 RB25det
Car: 1995 240
I
Sky240PWR wrote:nice numbers, have you ever ran it in the 1/4?
Ran a 12.9 on 18inch street tires, 16psi, a broken trans mount, a much smaller gt30. never dynoed it with the smaller turbo, so i have no idia what i will run now
ROB240
Car: 240 & Heep
I'm rob and I dont know how to log out of my sn at work, I also think I'm too good for RB's..
DriftingisLame
Car: '91 240sx coupe, rb20det
ROB240 wrote:I'm rob and I dont know how to log out of my sn at work, I also think I'm too good for RB's..
Its okay man, at least you admit it... oh, and no body's perfect, RB's will warm up to you and you'll see the light.
Good looking motor man, Looking forward to some #'s!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
LoL powned
fly240
Car: nissan 240sx
holly...smokennnn....that's at monster....very nice work...did you do all those work by your self or you have some shop doing it?....keep it update man....I wonder where did you get that exhaust manifold from?.....
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Whats up with your valve cover, did you just weld on bits of plate to make it look like a 25DET valve cover?
T4 RB25det
Car: 1995 240
t
AmoebAssassin wrote:Whats up with your valve cover, did you just weld on bits of plate to make it look like a 25DET valve cover?
the valve cover has a welded on catch can in it. thats why it also has the AN fittings.
I got the manifold from a shop out of thailand
fly240
Car: nissan 240sx
I wonder how big is it between gt30, gt32 and t3/t04e. which one would you recommend. I saw a gt32 under $700 that I probably will buy for my r33. any suggestion?. The gt32 has t3 divided flange, I wonder will this flange bolt to stock r33 manifold?....thank you...
T4 RB25det
Car: 1995 240
I dont know, i personally would never run a t3 flange on an RB25 but thats just me. i am coming from a 400whp integra, so i am used to nothing but top end power. any t3 flange should bolt up to the stock manifold, the question is weather or not it will hit the block. I made an adapter plate to run a t4 flanged turbo and it hit the block so i had to use a 4 inch extention to use the stock mani. i eventualy upgraded
I would say use the dual ball bearing turbo, that way you get alot of power and good response
i forgot about this thread, here are a few more updated pics of my setup
fly240
Car: nissan 240sx
T4RB25det...do you still have your t4 adapter hanging around....?...
T4 RB25det
Car: 1995 240
oh yeah, shoot me an email
krayton
looking real awesome.
body kit and some low offset 18s and i think your ready for race wars
scottsi
that looks exactly like the ssac manifold i have, the welds look exactly the same, the shape of the brace on top, i think its a ssac mani. which would confirm that they do work
T4 RB25det
Car: 1995 240
nope, i had the ssac, but it looked too flimsy, so i bought the phase 2. its about 3X heavier, and quite a bit thicker as well. still have the ssac in my garage tho
T4 RB25det
Car: 1995 240
krayton wrote:looking real awesome.
yeah but i guess my nos fogger is timed wrong, thats why im unloading in third. if i tune it down, i will runs 9's
240DRFT
damn thats nice. looks like a beast. wish i had a rb
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
your engine looks sick as hell! Great job on everything, i'll be eager to hear results on the new setup
-Dan
SillyRB
Nice set up, the pics look very clean. Lets see what type of #'s that GT35R puts down on a 2.5. I know of a few local Evos that have put down 600AWHP on that turbo. Let us know what it makes...and GOOD LUCK !
jamied311
Car: 91 Nissan 240SX Fastback
looks nice!
