My R50 and System pics.. Check it out...
Wkz1gg0a
Car: 99.5 Nissan Pathfinder SE limited edition
Well ive been on this site asking questions so finally decided to take some pics since theres some good weather outside. A lil run down of the system and other things- 1999.5 Nissan Pathfinder SE limited with 127,XXX miles brand new rebuilt transmission, just did a full tune-up Plugs wires cap ect.
MY SYSTEM CONSIT OF....
-Audiopipe 15001 class d amp
-Pioneer 600max 4 channel amp
-Pioneer H/U
-Clarion EQS 746 7 band eq with bass knob
-Two Soundstream 1in dome tweeters
-Two Audiopipe Atx-100 tweeters
-Four 6.5 Pioneer interior speakers
-Kinetik 600 rear battery
-4 gauge
Wkz1gg0a
All right i got the pics up properly..
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
take off the airbag warning sticker in the glove box... eyesore lol.
Wkz1gg0a
LMAO been there since 99. I had it folded inward i just moved the eq from the glovebox to under the Headunit and forgot lmao o well.
miamiheat3332
thats probably the first thing i rip off before even driving off the lot in either an new or used car hahaha
Wkz1gg0a
o0o lmao i still have all flyers and stuff that was on the car even the stock number key ring lmao idk like to keep eveything.
ganesh21
Car: '12 Honda Pilot
System looks great. I would use some loom tubing to make the wires look neat.
http://www.sonicelectronix.com/item_430 ... -Roll.html
fueler
Car: 2 Nissan's
2 BMW's
nice system!
PS you don't need "the club" in an R50 pathfinder. Our keys have a chip in them that need to be programmed, which thieves don't ever have. R50 parts are not worth enough for a thief to go through the trouble of finding an R50 ECU, mating it to a chipped key, and then swapping that stuff out when stealing a car. And if they DO go through all that trouble, then cutting a club off a steering wheel is childs play to such a thief. But trust me - it's not gonna happen.
If anybody breaks into your Pathfinder, it will be to steal the stuff inside.... but the Pathfinder won't move.
I regularly leave my QX4 unattended in bad neighborhoods in mexico with no steering wheel club & no worries whatsoever.
miamiheat3332
if you left it parked in my neighborhood unattended i just might have to take out those terrano lights, sell them and get a pair of terrano regulus ones fueler ;)
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
fueler wrote:nice system!
Plus the steering wheel lock and parking brake are always additional options. I try to remember to lock the steering wheel (just turn it one direction until it clicks locked when there's no key; to unlock pull the steering in one direction while trying to turn the key clockwise) and I always set the parking brake every time I park, before I shift into P. I use the parking brake because it puts the weight of the car on the wheels rather than the transmission's parking pawl, and it makes it significantly easier to shift out of P even on Florida's flat ground, and to prevent the car from rolling and potentially snapping the parking pawl if some jackass hits my parked car in some parking lot. Frequent use of the parking brake also prevents the brake cable from seizing up and rusting (though rust ain't an issue in FL) and I believe also adjusts the rear drums (though the manual says that every time the brake pedal is pushed, the brakes self-adjust, so I'm not certain). Of course the parking brake might require more frequent adjustment or other maintenance as a result, but whatever. There's a recent giant 5 page thread on BITOG about this very subject if anybody wants to read more anecdotes about the parking brake. :gapteeth:
Wkz1gg0a
Thanks for the system likes.. The club i rarely use just keep it as a quick weapon lmao when i least expect it. I know the key is chipped and stuff the R50 is hard to move that proably why my father felt dumb when he first purchased it in 99 and got swindled into buying LOWJACk which he kept paying for till i got it. Box is still in the car just not paid for in a few years... Might be upgrading the system to 4 12inch Alphasoniks I dont use the trunk what so ever pluss my spear is under the car lmao
shelby500krz
Car: 2001 Nissan Pathfinder LE 2WD
Or to make the wires look good you can try running them through the seat frame because all it is is sheet metal with foam.
